I'm with Stringmaker, and I recognize I misunderstood the basic problem. If you really want (but why would you???) impose a displacement between nodes not as an "initial" condition but as a constraint valid throughout the analysis, then the best way to go is with Constraint Equations (CE).
Via the Commands snippet, in WB you can do EVERYTHING you would do in Classical, EVERY element type is supported with ALL the keyoptions and real constants, BUT... remember that the geometry information is NOT accessible (so, identifying a node may be a headache) and you can not by-pass the mesh creation, i.e. you can not create a new mesh of your own overriding the original one, you can "only" add nodes and elements afterwards. Also bear in mind that these aditional constraints etc built up via APDL won't be shown in the Outline and will not be accessible to the Probe results: everything on them will have to be performed via APDL. However, with v.11 it is easier to show the results triggered by the APDL.
It's nothing impossible, I've managed since a long time to do things like that by myself without even one single call to the Ansys' Support, so don't give up, but I prefer you to know what you may face... ;-)
