I have a question regarding the way Icepak calculates the radiation and heat transfer by convection on a shared wall.
I am interested in specifying a certain heat transfer coefficient and radiation for two walls of a solid block. This solid block is surrounded by another block, which can be either a fluid or hollow block. This means the solid block shares certain walls with the fluid or hollow block. My plan was to specify the individual sides of the solid block as having certain external conditions, in this case, a heat transfer coefficient at a reference temperature, and radiating to a reference temperature and a specific view factor. However, I am noticing something unexpected. When the surrounding block is a hollow, only the external conditions specification seems to be working, while the radiation seems to be completely off. On the other hand, when the surrounding block is a fluid, the external conditions specification stops working (apparently replaced by the convection effect of the fluid block), while the radiation specification starts to work.
I have to add that the solid block has a higher priority than either the fluid block or hollow block, thus the shared walls should have the specified conditions of the individual sides of the solid block (or at least this is what I would expect).
Could you explain to me why is this issue happening? Ideally, I would like to use a solid block surrounded by a hollow block. Nonetheless, I cannot simulate the radiation effect of the solid block, even when radiating to a reference Temperature.
FYI, I am using Icepak 17.2.
Thank You!
-René
Thank You!
-René
