ANSYS fluid-structure interaction
NICOARG
Hi everyone,
I am working in fluid-structure interaction using ANSYS 13. I use it to obtain natural frequencies of structures submerged in water. The modal analysis results are good, but I can´t see the fluid pressure in the output, only the displacements. Do I have to use a command to display the pressure in the output?
Thanks!
