gianlucaforza86
- Jan 14, 2021
- 3
Dear all,
i need your help about a simulation on Ansys mechanical. I attached an overview about the simulated case. In this case I have 2 clamps. Linked to this clamps there's a point mass of 140 kg (not visible on the picture). I should tighten the bolts to increase the friction beetween the round pipe and the clamps. Additionally I shoudl calculate the minumum preload to avoid clamp rotation.
In my simulation there are 4 frictional contacts beetween the clamps and the round pipe, and a fixed supports on the pipe faces. The problem is that the system is not fully constrained (ansys error).
How could I proceed?
How could I calculate the min, bolt preload to avoid clamp sliding?
I thank you in advance for the support.
Gianluca.
Gianluca.
