controlnovice
Another water pressure problem in Colombia.
The lines in the picture represent 1/2 inch PVC pipe. Point B to C is about 50 meters. Point C is one user. The 4 branches leading 'down' are 4 other users along the line.
We don't know what the distance between A and B is. A is connected to a 1 inch line, to our knowledge...we haven't dug up anything yet.
The user at point C looses pressure often on an already very low pressure line. I don't have any pressure meters to know what we have, as we are in the mountains of Colombia. Of course, the 4 users at 1600m elevation have plenty of pressure and flow.
Since we don't know the length of pipe between A and B, I was considering changing the pipe between B and C from 1/2" to 1" to see if that would help user at point C. The problem with section A-B is it runs behind people's houses, through their yards. The piping was installed many years ago, and housing developed around it with no regard.
Is there any process/pressure issue with installing a 1" pvc pipe in section B-C without changing section A-B? Would it even help? Another option is to run a line parallel to the existing B-C section that only feeds user at point C.
______________________________________________________________________________
This is normally the space where people post something insightful.
