Mike is correct about the anodizing near a weld. Also significant is that the grain structure and tempering of the aluminum are changed near a weld, enough so that allowable stresses near a weld are significantly reduced from the unwelded condition. The net result of this... for instance, if you use a 6061-T6 tubing and weld it, the result near the weld will no longer be a T6 temper. Depending on many factors, it could be anything from a "dead soft" to T6 or other condition...you just don't always know, so therefore the reduction in allowable stress near welds (by code, within 1-inch of the weld).
