Angular tolerance...
trudels
7
Hi guys,
I want to know what would be the best way to show that I want a maximum misalignment of 1 deg. between the center axis of each part (hook and tube).
Refer to the attached file for more info.
Thanks,
Hmm, nothing simple springs immediately to mind. I'm wondering if using appropriate surface profile might get you in the right direction.
The problem I see here is that none of 14 geometrical tolerance characteristics in ASME Y14.5 is able to define tolerance zone that could grab your intent directly.
I would suggest using perpendicularity tolerance between both axes.
Assign one cylindrical feature as a datum feature A by attaching datum feature symbol to the diameter of this datum cylinder and then attach perpendicularity feature control frame to the diameter of second cylinder.
|perp|dia.X.X|A|
Knowing the length of the axis that is toleranced and allowable angular deviation, you could calculate maximum value of diameter of above perpendicularity tolerance zone. That is why I said you are not able to do it directly.
trudels,
Are your parts completly parallel, or just located to a datum plane? Your drawing looks like a rather complicated 3D projection. A 0[°] angle makes no sense in 2D.
JHG
