Angle dimension in a Drawing 1
quest4k
Industrial
Aug 31, 2005
382
Good afternoon, I have a model and I imported it into a drawing to dimention it. All was well till I tried to dimension the three tapered cylinder angles. I am trying this on the sectioned view and I am using ANSI dimensioning. What I would like to do is have SW put a horizontal dimention line under the taper cylinder and have the dimension arrows touch the cylinder angle and the horizontal dimention line and display the angle, which is half of the total taper angle. So far the only thing I can get is the total angle or the reverse of what I want using one of the vertical edges. I hope I am being clear enough here. Thank you in advance to anyone with a solution to this problem.
Can you please show a pic?
How Can I Show An Image In A Post
faq559-1100
Chris
Systems Analyst, I.S.
SolidWorks 06 4.1/PDMWorks 06
AutoCAD 06
ctopher's home (updated 06-21-06)
When dimensioning the sketch which creates the solid model, dimension it the way you want to see the dimensions in the drawing, then when in the drawing all you need to do is Insert > Model items & select the Marked for Drawing option.
Failing that, you may need to add a horiz sketch line in the drawing view to dimension from or dimension from the axis (centreline).
[cheers]
Helpful SW websites FAQ559-520
How to get answers to your SW questions FAQ559-1091
Thank you for the response CorBlimeyLimey. I kind of thought your response would be the answer, but I was hoping that there was some better way. Unfortunatly I was right. Thanks for the help.
I assume you are referring to the sketched line when you say, "unfortunately"
How about using the insert dimension function? Why dimension the same thing twice?
[cheers]
Thank again for the response, I have not hear of that one, where is it? What does it do? Can it pull in the taper of a cylinder?
One reason to dimension it twice is design intent vs. fabrication ease. Product design is much different from one-off machine design. Sometimes the best way to dimension a model for design tweaks is different from the best way to make the machining drawing.
See the Help files for Marked for drawing > Dimensions Overview and insert, dimensions into drawings.
[cheers]
Thanks again guys for the responses. handleman I agree with what you are saying, but I think this time I will try the insert dimensions thing. Thanks all and have a great weekend.
handleman ... that's where the Mark for drawing option and driver/driven options can come into play. Although I make my own drawings, I try to dimension the model sketches as if someone else will be creating them. That way if they ever have to, my design intent or manufacturing intent is carried into the drawing ... providing the Insert > Model Items is used.
Also it could be a long while between creating the model & creating the drawings, so it acts as a reminder for me ... and the way my memory is going, I need all the help I can get. [smile]
[cheers]
