I have been tasked with providing some steel rooftop platforms that anchor into existing parapet walls. I'm trying to do a bit of review on possible ways that this is done and ways to reinforce different types of roof parapets.
My initial thoughts are the addition of a platform spanning from two parapet walls (say in the corner of a building) when coupled with the wind load that the parapets are already exposed to will cause a moment that is greater than the parapets initial design strength. My thought would be to reinforce it with some vertical steel members to help strengthen the parapet against the reactions caused by the platform.
Once I find out the reactions of the platform I assume I can analyze the building parapet like a cantilever from the rooftop to make sure it can resist the new forces in addition to the wind loading on it. In the case where they do not have the strength to resist the forces I can add reinforcing to the parapets to provide the appropriate strength. My thoughts were through bolting channels or angles on the parapets to strengthen them however that may not be the best or most aesthetically appealing method.
I was curious if anyone has dealt with similar situations and had some input on this subject or knows of some good reference material in concerns to this subject.
