Larryhd2
- Dec 10, 2004
- 44
I had to go all the way through a footing with a retrofit holdown AB. I couldn't get an epoxy solution to work. Thankfully is it right near the edge and it has easy access.
I need to coat the AB and washer under the footing for corrosion protection. I asked that they coat exposed parts with Tnemec and infill the access hole with lightweight concrete. Come to find out that Tnemec is no longer VOC compliant in California. Now I'm going to have them provide HDG washer and nuts, but the end of the AB is still unprotected other than the concrete cover. They can't HDG the AB as the threads will be filled.
Does anyone know of a good alternative?... Perhaps a bitumen coating or other type of "rustoleum".?
