300redbeard
- Apr 29, 2009
- 24
Public Works Issue-21' tall abutment with 26' span
I have an issue regarding anchor bolt diameters. AISC table J3.3 states for 1/2" dia. holes: std-9/16", oversize-5/8" and long slot- 9/16"x1 1/4" respectively.
I have a bearing plate on a pedestrian bridge that the fixed end has 3/4" dia. holes for the A307 1/2" anchor bolts and the sliding bearing end has 3/4"x1" slotted holes with 1/2" anchor bolts.
The engineer of record wants to fix the oversized holes by 'A': use a 1/2" washer over a 3/4" washer. Table 6.1 AISC (RCSC): ok if washers not thicker than 5/16". If both washers are at extreme for thickness tolerance, they will exceed 5/16". Or 'B' use 1/2" thick plate x 1 1/2" x 1 1/2" with 9/16" dia. hole.
My concern is that this criteria is for standard oversized holes, not larger than oversized holes as I have stated for my case. Am I interpreting this correctly? Also the washers or the 1/2" plate will bear next to a 1/4" fillet weld, this will result in the washers or plates taking the lateral force instead of the anchor bolts.
Thanks for any comments!
