ClearCalcs said:
KootK, I was also thinking about just ignoring the concrete and went down a bit of a rabbit hole. Curious to hear your thoughts on this!
I accidentally baited your here I'm afraid. I was being facetious and wouldn't, myself, seriously consider the steel only option. Fundamentally, I just don't like designs that pretend that things work in a manner which we no to be substantially false. And I feel that would be the case with this. Granted, one might still be able to argue it as a lower bound solution. Still though, like you, I find these things fun to think about. In practice, I've kicked around the idea of using steel only as an upper limit on deflections. Even that gets a bit messy, though, when one considers the impact that the ignored concrete has on the rebar in between T&s cracks etc.
ClearCalcs said:
Is it even possible for a/2 to be greater than d’ with As = As’?
I'm afraid that I don't know. Obviously, a/2 greater than 'd' wouldn't represent a statically admissible solution with the bars assumed fully yielded. But, as we know, they're not fully yielded. To answer this question fully, on might have to study the section paying strict attention to strain compatibility, perhaps using a stress block assumption more advanced than Whitney's, and maybe redefining what is meant by "a" in this context. Somebody like Denial, IDS, or rapt would be a good fit for this question, hopefully one or all of them stop by.
ClearCalcs said:
Can we really rely on the concrete for shear flow between bars then?
Another fine question. And another reason for me not to do this. In addition to trying to avoid solutions that don't mirror reality, I also try to avoid solutions that haven't been vetted through testing. And this issue would probably be one of those. Some thoughts:
1) I would think that the concrete
betwen the bars would be most critical for shear flow. And everything between the bars should remain at modest strain levels.
2) If the stain beyond the bars is extreme, it may spall the concrete there and compromise bar bond.
That would certainly compromise shear flow.
3) Other than cantilevers, most common design situations have low-ish shear at locations of peak moment. This might help with #2.
