Analysis - result Window
  • Thread starter Thread starter Ferincz
  • Start date Start date
F
Ferincz
Guest
When in a current session I try to open result windows created in a previous session, I get the meesage that "One or more result defenitions couold not be opened", and I can not open the .rwd file.
I also get the same message when the analysis directory is saved on a CD at the end of a session, and later I try to open the analysis on an other computer (copied to its hard drive, and ProEis the same version).
Any help would be appreciated.
Ferincz
Ferincz,
This is an old problem that mechanica, for what I see, has not been fixed. The reason I believe you are getting this error is because the .rwd file is path dependent. What I mean is that whatever path location of the folder you had the first time the .rwd file must be maintained when you transfer it to a different computer. You may want to call costumer support to see if they have a work around.
Luis
Thanks! I'll let you know if I get an answer worthy to post.
Ferincz
