D
deedub777
Guest
Hi all,
Interesting problem, wondered if you gurus could help out. And all this needs to be done using basic ProE (no mechanica or fluid tools
I have a simple water tank with a given volume of water (say, 2 litres) and need to evaluate the water level if the tank is tipped through 35deg in any direction. So I guess I need a parameter that shows the water level given the volume.
Any ideas?
All I have managed so far, is build a part that is sketched from the base of the tank and extruded upto an assy datum. The rotate the "tank" part in the assy and regenerate. This achieves the correct water level but not volume.
Any ideas?
