MrFurleyEIT
I have got a question about the analysis and design of tapered-section columns, either in a pre-engineered building, or in a steel structure. What is the best way to approach this? What is the theory behind it?
Now, I have done some design for columns for purely axial loads, and for beam-columns for axial compressive and bending loads. I am pretty comfortable with W-shape columns, but am not too familiar with tapered-section columns.
I remember my boss asking me to evaluate a tapered-section column, and I was kind of stumped!
I guess the reason I am not entirely sure is because the section of a tapered-section column, by its very definition, changes constantly along its entire length. Which area, and hence, which rx, ry, Ix, Iy, Sx, Sy, etc. should I use?
Also, a tapered-section column is as if it were several members in one single column, and their properties varying as the column go upwards or downwards. Appreciate if someone could provide the theory behind the analysis and design of a tapered-section column, relevant formulas, a worked example, e.g. Relevant references with page numbers would also be most welcome.
Thanks a lot.
Thanks a lot.
