I'm trying to use an inductive clamp from a timing light to pick up RPM signals for a chassis dyno. I need <10V but enough for the Dataq DI-148U I'm using to read. I've tried finding a usable signal off the timing light itself, and an AD8230 in-amp in a couple different configurations. With the amp I get a signal but it makes no sense. I'm using the AD8230 in-amps for bridge and thermocouple measurements. The data sheet made that easy. Could one of you point me to a suitable amp and schematic for what I'm trying to do?
Thanks,
Kevin
Thanks,
Kevin
