Primero que todo, apreciaria que me contestaras en el idioma que te escribo. No tengo ningun problema en hacerlo en Ingles, pero pienso porque estas en Mexico es mejor explicartelo en Castellano.
Your dust collector is only doing its job. And that is to purge the dirt off the filters when needed. You can easily turn this feature off, just read the manual of the Torit Dust Collector? or better yet, adjust the cleaning cycles.
Your compressor isn't supplying enough air to handle the machine needs, the beam purge, dust collector, plain and simple. The question is, Are you using this compressor for the whole shop? Just the beam purge alone will require a constant 90 psi, and without it, you might as well forget it.
In regards to speed. I would certainly use the conditions provided by the company for now. These are very conservative speeds for production. Once you get some experience under your belt, then you can start modifying these cutting conditions as you wish. The only thing you need to worry about getting right is Focus, this is the key to everything.
Please keep in mind that I do not work for Amada and I only do this to help, you don't have to follow any of my advice if you don't want to. I know this machine like the back of my hand because I used it since the very day it came out up until a few months ago.
