I don't think so. First, the subject is the flange ending the pipe spool that will be attached to the flange on the PV.
Secondly, my piping design engineers apparently have far more knowledge and responsibility than yours. If there are any line specs at all, my piping design engineer will determine the applicability of a particular line spec to the pipe being designed. If there are no line specs, my piping design engineer will determine the material, pressure class and wall thickness required for each pipe to be designed. Then, if needed, he/she will write the line specification for that pipe any and probably all pipes to be used on the rest of the project.
“What I told you was true ... from a certain point of view.” - Obi-Wan Kenobi, "Return of the Jedi"
