JJJackbk612
Hello, I am trying to find some aluminum spring material. The shape of the spring needs to be rectangular (1 ½”L x 3/8” W x 1/16” D). I don’t know the spring constant at this point but it has to be higher than what you get from typical material machined out of stock from the hardware store.
The spring will be held at one end and the other end will be moving in an arc. I don’t know the spring constant but I know what displacement I need from the high tension position to the low tension position and that’s about 5/8”.
My question is: does anyone know where I could purchase such a material even if it was not that exact profile that I need I could machine it.
Thanks,
Jacques
Thanks,
Jacques
