DCStructures
- Apr 19, 2007
- 46
I am designing a base for a sculpture. The artist would prefer that the base be stainless steel, the sculpture be aluminum, the connecting plate (between the sculpture and the base) be aluminum, and the bolts (between the connecting plate and the base be stainless steel. This is a temporary installation, expected to be up for one year. It will be located outside, but not in a coastal environment. How much corrosion should I expect in one year? Is the expected amount of corrosion enough to break the bolts or any of the other pieces in one year? Thanks!
