aluminium extrusion snap design
Teunis
NL
Can somebody give me some directions in finding a good design-guide for Snap-fit design in aluminum extruded parts ?
TIA.
Take a look at plastic snap-fit design guidelines. You can probably find it easily enough if you do a search on the internet. The only thing that is really different are the material properties between aluminum and plastic.
- - -Dennyd, P.E.
Aluminum Association has a design manual which can be purchased from their website. I use it every day and answers all of your aluminum design questions. I found by using this, the mills give fast turn-around to die designs when you spec as per the design manual.
(If I remember correctly)
