I have a 2.0" X 2.0 X
.125" Alum tube top frame member,attached to a existing upper square
frame,
supporting a 300 Lbs load box. What is the shear stress load on the
single alum 2x2x.125" tube member. Only a rough estimate only, I just
wanted to see the
approx results of this member.
Tube top would be the 2x2x.125" square Alum, that the 300 Lbs box is
resting on. I drew this pic to give sample;
I realize this is only a partial picture, What formula would i use to
calculate this? Thank you very Much
frame,
wanted to see the
