brutus1955
- Aug 19, 2003
- 57
if we have an alternator, it produces AC
and assume it is 3 phase for the sake of discussion
attached to the alterntor is a bridge rectifier to convert the AC to DC
the power factor of a circuit driving a rectifier is reportedly something less
or often much less than unity
now granted an alternator that has its rectifiers mounted internally has the worlds shortest transmission lines (from alterntor to rectifier load), but
the winding of the alternator also take the hit for poor power factor
reciculating or reactive power produces no useful work, but
it does take up ampacity of the transmission lines and the stator windings as well.
in a perfect world an alterntor should be near unity power factor driving the rectifier...
now the question
how would one determine the power factor of an alterntor, between the stator and the rectifier?
if the stator three phase leads are also externally accessable at the rear of the case, could one simply start adding a bit of capacitance while watching for the field current to dip, while while supplying a fixed load?
it would appear that one could start adding capacitance and watch for the field current to start to drop, which would be evidence of the stator voltage starting to climb due to power factor being overunity. one could then reduce the capacitance sufficiently to assure that the power factor was comfortably and safely below unity.
there is a reason that i need to know this, i am slicing things very thin right now looking for the last percent or two in efficiency of a system.
poor power factor has no cost in power in as much as no useful work is done, therefore no work is needed as input power, but
reactive power takes away ampacity of the system, and in doing so creates heat
heat takes input power to generate.
anyone got some thoughts on this topic? or see anything wrong with the theory of adding capacitance?
bob g
now the question
bob g
