I'm sure this must have been covered somewhere but I can't find it.
I'm trying to find the exact engineering definition of a Generator and how it differs from an Alternator.
I am aware of two different definitions and I'm struggling to find which one is correct.
1) Generator is a generic term for any device which converts mechanical energy into electrical energy. Thus an Alternator is a type of generator.
2) A Generator is specifically a device which uses a static magnetic field to induce an AC current onto the rotor which then uses a commutator to produce a DC current. Whilst an Alternator uses a rotating magnetic field to induce an AC current in the stator?
If definition 2 is correct them I am content.
If definition 1 is correct, then I am happy that an Alternator is a type of Generator which uses a rotating magnetic field to induce an AC current in the stator. BUT... what is the technically correct term for device which uses a static magnetic field to induce an AC current onto a rotor which then uses a commutator to produce a DC current (as the term Generator is too generic to cover this exact application).
I hope this makes sense?
