Greasy Hands
Aerospace
Hello all:
I'm tinkering with how to allow slip between two hydraulic wheel motors used to propel a small tractor. Originally, I was going to control each motor with a dedicated double acting spool valve to provide both motive power and steering. However, the design evolved to use dual wheel motors for propulsion only and to provide steerable front wheels instead of casters. Ordinarily, I would drive two hydraulic motors using a flow divider, however, in a turn the outside wheel will needs to rotate faster in order to keep up with the turn. Of course, I don't want to be dragging the outside wheel. How can I allow for a higher oil flow to one wheel when turning? I am certain that this is not a unique idea, but I have never seen it applied.
Greasy Hands,
Austin, Tx
Greasy Hands,
Austin, Tx
