I'm aware that allowable LL deflection limits vary based on use, but in this instance, lets assume that L/360 is acceptable for a residential application. If say, 10ft spans, the allowable LL deflection is 0.33inches. If the floor is sagging under dead load only, at say 0.25inches, or even 0.33inches, would you deem this not acceptable? At what deflection limit would you consider acceptable for DL only??
