when doing an FEA that includes clamping forces for fasteners in a bolted joint, what is the allowable stress for the area under the bolt head that's subject to the clamping force? When you have a joint with large diameter fasteners, and allow for a ~20000 lbf clamp load you can see higher than typically allowable stresses (>.6Sy) under the bolt heads just due to the clamping force, w/o any external loading.
So, assuming these stresses are away from the edge of the part, and there's no fatigue loading, what's an "industry" acceptable value for these stresses under the bolt heads? By this I mean referenced to some sort of code, from a reliable source, etc- something that I can quote.
I have an analysis report someone else did that uses a value of .9Sy for this, but I'm not sure where this came from. I've tried googling, but bearing stress is typically referenced to shear so maybe I'm not using the correct terminology?
Thanks In Advance!
Thanks In Advance!
