I designed a cantilever beam with a moment connection to a column web using a web plate for shear and bolted flange plates for the moment. However, the contractor just welded around the beam end to the column - no web plate, no flange plates, no bolts! I now need to check this to ensure that the connection is adequate. Can anyone direct me to an all-welded moment connection design or example? I know that I came across an example a few years ago but I cannot remember the reference. Any help or guidance would be appreciated. Thanks!
