Kenton54,
PHENOLPHTHALEIN is correct.
One manufacturer is RICCA CHEMICAL COMPANY, Arlington Texas.
Also, as Ron mentioned, small diameter cores are a good method to obtain a sample (that you fracture longitudinally, as he states). We use a HILTI hand-held core machine that works well for small diameter samples (1.5" for example), and avoids having to mount the rig with drop-in anchors or use a vacuum base.
HTH
