AISI equivalent for ASTM A551-65-C 1
kertaker
Am looking for an AISI or SAE equivalent for ASTM A551-65-C. Any assistance would be greatly appreciated.
kertaker;
I don't have a copy of this specification at work. However, I will check on this at another location.
My question is this;
Since this ASTM Specification pertains to material for locomotive tires, does material substitution pose a problem with AAR Standards?
metengr,
Received this material specification for a riding ring to be used on a rotary drum. AAR Standards do not apply.
Thanks.
ASTM A 551 Standard Specification is for Steel Tires used in railway and rapid transit. Class C material is for untreated tires, used in switching locomotives.
The following chemical composition range applies to Class C material;
Carbon 0.70-0.85%
Manganese 0.6 - 0.90%
Phosphorus 0.050% max
Sulfur 0.050% max
Silicon 0.15-0.35%
As far as an equivalent AISI steel grade, the closest matches are either AISI Type 1078 or Type 1080 carbon steel. For heat treatment, A 551 only specifies a “slow cool after forming to accomplish proper transformation without damage”. For the AISI material equivalent, I would have it supplied in an annealed condition.
metengr,
Thanks for the help. Any idea what the "-65" designates?
You know, I was wondering about that, and the only possible reason I could think of was the year of the ASTM Standard.
Thanks for all of your help!
Happy Holidays!
