I need help understanding an aspect of this guide. I have a W24x162 with a 6" diameter hole with the opening edge 4" from the bottom of the beam. The guide establishes ho = Do = 6" and ao = .4Do = 2.7". Now for my question...The parameter ∝ν must be <= 1.0. When calculating ∝ν, the result is less than 1.0. The guide does not explain why this would be the case or what bearing it has on the calculations. My confusion is this is a relatively small penetration, which is located more than 0.15d, why should there be any problem with these calculations?
