Hi, I need some help on what equations to used, I need to find the Air Flow Rate in a pipe. Air is compressed in a tank, it comes out in a pipe of 3" diameter then it goes thru a 1" orifice(length less than 1/2"
and goes back to a 3" pipe. The inlet pressure is 35psi and oulet pressure is 27psi (controlled). Do I need the Length of all the pipe or what?, please help me with this problem by telling me what formulas and procedure to use, thank you very much.
the equations i am trying to use are:
v=((25000dp)/L)^(1/2)
Q=Av
What else do I need, how do I find the pressure loss do to pipe length,
thanks for your help.
EJ
Q=Av
EJ
