jf1991999
- Nov 12, 2008
- 1
I am looking for a low cost way to fix a 200mm diameter extruded cylinder to a steel Y bar section. I can't use traditional fasteners in this application.
I have decided that a press fit should work well. I would use an injection moulded disk shape with a thickness of around 25mm. 2 of these disks would be pressed into the extruded cylinder with a spacing of about 200mm. The disk would be moulded with a cut out of the Y bar section running through it so that the cylinder could be pressed onto the Y bar and held in position via the interference fit between the 2 disks and the Y-bar.
I have not had much experience with injection moulded plastics under load. There will not be much load on this joint although I need it to be reliable for 30 years. The plastic disk will be subjected to reasonable compression to securely fit it within the cyclinder and to securely hold the Y bar. UV, chemical exposure and temperature are not an issue. Water is an issue. My questions are;
1. Will the plastic flow over time and 'relax' the interference fit between both the cylinder and y-bar.
2. Could I get some recommendations on the type of plastic to use for this application.
3. Are there any formula's that help in the design of interference fits like these between different materials.
4. Is a 30 year design life possible for this type of fixing?
