I decided to write this tip after a short discussion with master here, JustKeepGiviner (JKG) about relations patterns which involves advanced knowledge of ProE, For those of you want to learn advanced techniques about patterns, please see the JKG example of the following thread: Pattern Tables and Layouts - thread554-154663.
I will not talk about advanced patterns here, but about an amazing tool ProE put in our hands: MOVE COMPONENTS IN ASSEMBLY MODE.
I still on ProENGINEER 2001, so you must find the similar way to do in WILDFIRE.
Create an assembly, (3 datums+ a CSYS) and assemble the first component let's say a plate. The easiest way is just to use CSYS on CSYS. Then assemble on this plate anothe part (a cube). I mated with the big plate, 40inches in x direction and 0 in z direction. There is no way to move, rotate or pattern the cube if your part is fully constrited, as we wish! Well here is the tricky part.
From assembly menu, choose the option MODIFY->MOD ASSY->MOVE->select assembly CSYS -> select your part -> Rotate->choose y axis (for example)-> give a value (let's say 30)-> Done. Then regenerate. Surprise! Your part is rotated with 30 degrees! Now guess what? You can use this rotation as a base for a pattern! Let's pattern the cube: Choose COMPONENT-> PATTERN->select the cube->select the angle dim you just created->give a value of 30->done and put 6 for number of instances (you can use any numbers you want). Now you'll have a nice pattern.
But this is not all! Now the fantastic part:
Select again MODIFY->MOD ASSY->MOVE-> select the CSYS of the third pattern instance -> select the third instance cube->ROTATE-> Y axis-> put 45 degrees-> Done-> Regenerate.
Surprise! Your third instance has been rotated with 45 degrees. But only this one! Did you ever think you can do this in ProENGINEER?
Go ahead and select again MODIFY->MOD ASSY->MOVE->select assembly CSYS -> select the third instance-> TRANSLATE-> X axis-> give a value of 20. Regenerate! That was cool, right?
Remember, you can add any time new dimensions for the part already constainted. You are limited by your imagination.
But there will be too nice to be parfect! In fact you will loose all the dimensions you created if you redifine your cube! That's only negative thing about this method.
I hope you will appreciate this incredible feature of ProENGINEER wich in many cases, will help you a lot!
Good luck,
-Hora
Good luck,
-Hora
