Hello! Long time reader first time poster.
Normally if I search enough I can find my question already answered, but not this time... There are two problems wrapped into one, so any help would be appreciated.
I am trying to design a very simple assembly. It is a bended piece of sheet metal with X length. To keep the part stable, it will have some steel welded onto it underneath. This part will be (X-160mm) long.
Both of these parts are defined as adjustable by length in their respective psm/par files. In this assembly, I can change the length on each manually.
However, I would like the overall length of the part to drive both parts. If I say that X=1000mm long, I want the stabilizing part to automatically adjust to 840mm. However, when right click and click "Edit Adjustable Part," I can define the length with a value but I have no luck trying to put a forumla in. (I can't find a good forumla rules list anywhere for SE, so I could just be inputting this wrong!) The Variables window hasn't been of much help either.
My other question, once this problem is solved, is if I could put this subassembly into a larger one and still adjust it.
(To give some context, I work with physically very large assemblies that have moving parts. We have a lot of pieces that have welded components that is a subassembly in SE. I want this welded part to be able to be placed into a larger assembly and I can modify the lenth within the design and be specific to that design. The manufacturing drawing for this will be variable by a length we determine and define on every project)
Any feedback would be helpful!
