SteveGregory
- Jul 18, 2006
- 554
For typical 3 ft, 4 ft and 5 ft square footings (f'c = 3,000 psi and net soil bearing = 2,500 psf), it appears that I must hook the ends of the footing rebar on each end or increase the number of bars per Section 12.2.5 or increase the size of the footing. This is because the length of the bar from the critical moment location to the end of the bar is shorter than the development length [cantilever length-cover].
Most of the time, the area of steel required is governed by 0.0018bh (Temp steel). Is the "As required by analysis" in Section 12.2.5 referring to Temp steel if it is the minimum that governs or the As calculated for flexure only?
Or does 12.2.5 not apply to spread footings?
