Does anyone have experience with bolted shaft couplings that employ a friction modifier between flange faces, such as an anaerobic acrylic adhesive (possibly from a certain threadlocker manufacturer)? Can anyone suggest a type that provides high shear strength, but doesn't harden? I'd like to be able to dismantle them.
Would anaerobic pipe thread sealant do the trick? The coupling I'm working on is submerged in water, so resistance to polar solvents is a plus.
The manufacturer of the coupling spec's a nitrocellulose lacquer paint mixed with boron-carbide, sprayed across one face. While this may work, I find it a bit unorthodox, plus the paint thickness variation could quite possibly affect the coupling alignment (it's supposed to be dry before coupling). I would get a more warm fuzzy feeling if the coupling was performed with a liquid/gel/paste so there would be opportunity for full metal to metal contact with the friction agent filling in gaps only, not creating its own gaps - it could lead to fretting damage if the bolt tension is not quite high enough.
