adding krx in fastener command 2
ChevyM
Automotive
Feb 9, 2012
90
i was wondering, and probably it's possible, but i have no idea how i can do this:
i want to create a fastener assembly with this part:
sorry, my native language is not english and i can't find the english word for it. sorry for that.
can i create this part as a KRX file and input it in to the reuse library so that the fastener assembly command can see my own made part? cause right now it only sees the parts that are already integrated in NX.
Best regards,
Chevy
NX6
Win7, 64 Bit
Attached is a how-to document (section 6.2 covers KRX files) and some template files which may help you get started in the right direction.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
UG/NX Museum:
oke, thank you very much!
i will look in to it.
Best regards,
Chevy
NX6
Win7, 64 Bit
dont want te be a drag John,
but the only usable item in that file is the word document right? cause the 2 .prt's are nothing and i can't open the .dpv(also have no idea what it is)
Best regards,
Chevy
NX6
Win7, 64 Bit
Yes, that's correct. BTW a .dpv file is where customer defaults are stored and while it's possible to read them using any text editor, they don't make much sense to us simple humans ;-)
John R. Baker, P.E.
Industry Sector
Cypress, CA
UG/NX Museum:
hahaha, oke;)
i was wondering in the part i posted earlier is in the Machinery Library? i was looking for it to download, but couldnt really find it on siemens website or on google, could you help me out with that? is it a handy library?
Best regards,
Chevy
NX6
Win7, 64 Bit
found it! and downloaded everything
would also wanted to say that on page 11 at the bottom:
it says: "Thinckness"
don't know if u can edit it, but i think it should be thickness right:p?
thnx for the information though!
Best regards,
Chevy
NX6
Win7, 64 Bit
BTW, my comment about .dpv files not "making much sense to us simple humans" was of course meant to be facetious, but if you really feel that you'd like to see what's actually in a .dpv file (or any XML file for that matter), just drag the the file onto an open browser window.
John R. Baker, P.E.
Industry Sector
Cypress, CA
UG/NX Museum:
oke thnx =] i'll look into it
is there a way to ge those Machinery library parts in to the Fastener command?
Best regards,
Chevy
NX6
Win7, 64 Bit
Do you mean the 'Fastener Assembly' function?
If so, when you pre-define typical Fastener 'stacks' using the 'Configure Fastener Assembly' function, based on the Standard selected, you will have access to the various relevant fasteners from the Reuse Library.
Search the NX Help files for 'Fastener Assembly' (or open the 'Configure Fastener Assembly' dialog and press the F1 key) and you will find stuff which will help you set-up these fastener 'stacks'.
John R. Baker, P.E.
Industry Sector
Cypress, CA
UG/NX Museum:
thats exactly what i meant!
thank you!
Best regards,
Chevy
NX6
Win7, 64 Bit
i do have a problem..
when i press F1 or go to the help files, i get this error:
"Unable to display help information.
Application contect not found"
is this because we use multiple HD's and NX can't find the help files?
Best regards,
Chevy
NX6
Win7, 64 Bit
Look into your log file (Help - Nx Log file)search for the word Help in the file.
Should be a (network) HD path like this :
UGII_CSHELP_DOCS "path to help files"
Probably it points to the wrong directory or network path.
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit (Intel(R) Xeon(R) CPU X5650 @2.67GHz)
24.0 GB
NVIDIA Quadro 4000 + NVIDIA Tesla C2050
well.. i did find it and it says that it doenst exist, so where should the help file be in? it says: C:\Program Files\UGS\NX 6.0\ugdoc\html_files
but the "ugdoc" map doesnt exist
Best regards,
Chevy
NX6
Win7, 64 Bit
Where are the help files then? You could make the directory and copy the full help documentation to there. But keep in mind, it's about 6Gb on size.
Best regards,
Michaël.
24.0 GB
thats the whole problem, i dont know where they are since i need them.. is there a way to obtain them?
Best regards,
Chevy
NX6
Win7, 64 Bit
They are separate from the install DVD. But i think you can obtain them via the GTAC site.
You need a valid webkey and login for this site.
Best regards,
Michaël.
24.0 GB
ah oke thnx :D i have those, will look in to it!
Best regards,
Chevy
NX6
Win7, 64 Bit
oke, i have it installed but..
it doesnt say anything about putting hex socket bolt in..
only this: Use this command to add an individual fastener or Fastener Assembly (bolts, screw, nuts, and washers) into selected holes automatically. The fasteners are retrieved from the NX Machine Library, which has a large variety of ANSI, Inch, Metric, ISO, JIS and other standard hardware. The fasteners are fully parameterized NX parts.
but i only have acces to the normal hex bolt and nut.. (see attachment)
so how do i put those others bolts and nuts in? since i only have the basic nut and bolt..
Best regards,
Chevy
NX6
Win7, 64 Bit
 http://files.engineering.com/getfile.aspx?folder=39cc0b77-02ab-4260-95af-235fd6bca72f&file=fasteners_no_variation.jpg
and i do have the machinery library installed and have acces to it, but i dont have acces to it from the fastener function.. (sorry for the double posts..)
Best regards,
Chevy
NX6
Win7, 64 Bit
