Add-ins in Ribbon
pktnat
I am trying to use the new commands from Add-in "3ds Export for SolidEdge". The file ReadMe says the application will add a new submenu under Add-ins, and I've seen internet screenshots of this submenu located in the ribbon in a tab called 'Add ins', but my ribbon does not contain this tab.
Does anyone know how to make the Add-ins tab appear in the ribbon?
I am in dire need of this. Any help would be greatly appreciated.
Is the Addin turned on? You can check in the SE application menu in the upper right corner and pick the addin menu.
Yes, I'm already far ahead of that point. I just figured out the problem, though. The add-in I had downloaded was for a previous version of SolidEdge (with menus instead of the ribbon). After downloading a newer version, the tab appeared.
Thanks for the prompt reply though :)
Ah! Well, good you got it working then.
