Does anyone have any document or information over how to add custom parts into the standard parts library using database administrator.
I allready tried to learn from the basic standard fasteners. But don't understand it at all.
Example:
When a bolt with a length L of 45mm does not have a 'full thread' in the Database Administrator the threadlenght is called TX with a value of 26mm. In the part-environment the variable list of the created part doesn't show this 26mm, but give the lengte of the non-threated part of the shaft (L-TX=19mm). I also cannot find the headwidth in the DB administrator.
Example:
