Adapt Journal to only select specific colors?
Kenja824
Automotive
Nov 5, 2014
950
This code takes the curves one selects and changes them to specific settings.... (Coler, Type, Etc..)
How hard is it to change this so the selection only allows one to select specific colored curves? The only colors I want to be able to select are 31 and 7.
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Module NXJournal
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim workPart As Part = theSession.Parts.Work
        Dim displayPart As Part = Nothing
        Dim ufs As UFSession = UFSession.GetUFSession()
        Dim mySelectedObjects As NXObject()
        Try
            displayPart = theSession.Parts.Display
        Catch Ex As NXException
            ufs.UI().DisplayMessage("Please set drafting mode before running the journal", 1)
            Exit Sub
        End Try
        If IsNothing(displayPart) = True Then
            Exit Sub
        End If
        Dim markId4 As Session.UndoMarkId
        markId4 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Edit Object Display")
        If SelectObjects("Select Curves to Change",
        mySelectedObjects) = Selection.Response.Ok Then
            Dim displayModification1 As DisplayModification
            displayModification1 = theSession.DisplayManager.NewDisplayModification()
            displayModification1.ApplyToAllFaces = False
            displayModification1.ApplyToOwningParts = False
            'displayModification1.NewLayer = 242
            displayModification1.NewColor = 152
            displayModification1.NewWidth = DisplayableObject.ObjectWidth.Two
            displayModification1.NewFont = DisplayableObject.ObjectFont.Solid
            Dim count As Integer
            count = mySelectedObjects.Length - 1
            Dim objects1(count) As DisplayableObject
            Dim i As Integer
            i = 0
            For Each mySelObj As NXObject In mySelectedObjects
                Dim body1 As Curve = mySelObj
                objects1(i) = body1
                i = i + 1
            Next
            displayModification1.Apply(objects1)
            displayModification1.Dispose()
        End If
    End Sub
    Function SelectObjects(prompt As String, ByRef selObj As NXObject()) As Selection.Response
        Dim theUI As UI = UI.GetUI
        Dim typeArray() As Selection.SelectionType =
        {Selection.SelectionType.Curves, Selection.SelectionType.Curves}
        ' {Selection.SelectionType.All, Selection.SelectionType.Curves}
        Dim resp As Selection.Response = theUI.SelectionManager.SelectObjects(
        prompt, "Selection",
        Selection.SelectionScope.AnyInAssembly,
        False, typeArray, selObj)
        If resp = Selection.Response.ObjectSelected Or
        resp = Selection.Response.ObjectSelectedByName Or
        resp = Selection.Response.OK Then
            Return Selection.Response.Ok
        Else
            Return Selection.Response.Cancel
        End If
    End Function
End Module
Ken
My brain is like a sponge. A sopping wet sponge. When I use it, I seem to lose more than I soak in.
