Adams Car Assembly (Adams 2017.1) |
command: !
command: !INFO Adams Version: Adams 2017.1
command: !INFO Adams Build: 2017.1.0-CL475821
command: !INFO Assembly File:
command: !INFO Solver Library: C:/MSC~1.SOF/Adams/2017_1/win64/acar_solver.dll
command: !
command: preferences/solver=CXX
command: preferences/list,status=on
PREFERENCES:
SIMFAIL = NOSTOPCF
Contact Geometry Library = (not loaded)
Thread Count = 1
Library Search Path = Not Set
Status Message = On
Solverbias = CXX (C++ Solver)
command: control/ routine=acarSDM::con950, function=user(950,29,31,1,2,18,20,1,3,2,3,28,30,2,3,28,30,1,1,0,0,0)
Begin Static Solution
STATICS: Original static solver will be used with the Sparse linear solver.
---- START: ERROR ----
Static equilibrium analysis has not been successful.
The maximum number of iterations 25, has been reached.
For the last attempted iteration:
The equation with the largest error was model.REAR_SUSPENSIONN.nsr_SPRING.force Comp = 0 Error = 6237.821732
The variable receiving the largest increment was model.REAR_SUSPENSIONN.ger_FOX_MOUNT_CHASSIS Comp = 5 Delta = 980677.163237.
---- END: ERROR ----
Static Solution failed to converge
End Static Solution
Simulation failed
Initial Static Sim. Not Successful
Adams Solver (C++) run terminating due to STOP requested by user.
Termination status=-995
Terminating Adams Car usersubs...
Finished -----
Elapsed time = 0.30s, CPU time = 0.28s, 92.82%
Analysis failed!
Please check the error messages to determine the cause.
I'VE MADE THIS TEMPLATE BUT FACING AN UNKNOWN JOINT ERROR ON SPRING TOP MOUNT
CAN ANYONNE PLEASE CHECK OUT THE TEMPLATE ATTACHED AND HELP US OUT.
THANK YOU.
command: !
command: !
PREFERENCES:
SIMFAIL = NOSTOPCF
Thread Count = 1
Status Message = On
End Static Solution
Simulation failed
Finished -----
Analysis failed!
THANK YOU.
