ADAMS Constant Radius Cornering simulation fault 1
konrad.stachon
Student
PL
Hello, I keep running into this error message when trying to set up Constant Radius Cornering simulation. I was ok, before I changed CM location.
---- START: ERROR ----
At time 7.708098512E-01 the integrator is unable to start/restart. Possible Causes:
(1) The accuracy required for the numerical solution can not be attained.
Relax (increase) the value of the acceptable integration ERROR.
(2) Incompatible redundant constraints, a lock up, or a bifurcation
situation. The latter two indicate a mechanism design problem.
(3) The system includes a zero (or relatively small) mass on a part with
an unconstrained translational degree of freedom.
Make sure you have mass on all parts with translational degrees of freedom.
(4) The system includes a zero (or relatively small) inertia on a part
with an unconstrained rotational degree of freedom.
Make sure you have inertias on all parts with rotational degrees of freedom.
(5) An Adams element has a function expression that equals exactly itself.
For example,
SFORCE/id1,I=id2,J=id3,ROT,FUNC=SFORCE(id1,jflag,comp,rm),and
DIFF/id4,IMPLICIT,IC=0,FUNC=DIF1(id4).
Similarly,
VARIABLE/id5, FUNC=VARVAL(id5)*TIME
equals itself at 1 second. Avoid setting an Adams element equal to itself.
---- END: ERROR ----
Dynamic Solution stopped.
End Simulation
Simulate status=-124
SIMULATE command failed for minimaneuver: STEADY_STATE
Aborting Execution.
Adams Solver (C++) run terminating due to STOP requested by user.
Termination status=-995
Terminating Adams Car usersubs...
Finished -----
Elapsed time = 10.93s, CPU time = 10.13s, 92.63%
Simulation is complete.
I tried that too. Thank You once again for help, if I solve this problem I'll write what was wrong.
