mathcadboy
21.3.2.2 — Positive moment strength at joint face
shall be not less than one-half of the negative moment
strength provided at that face of the joint. Neither the
negative nor the positive moment strength at any section
along member length shall be less than one-fourth
the maximum moment strength provided at face of
either joint.
Here is the scenario,
At the support,
From DL + LL Load combos,
top bar req't : 7 bars
bottom bar req't : 2 bars
From Seismic Load combos,
top bar req't : 4 bars
bottom bar req't 2 bars.
obviously 7 bars for top reinf governs. The question is do I still need to add bottom bars so that I can make my positive moment strength greater than half the negative moment strength? seismic moment is quite low.
Thanks in advance to all.
either joint.
At the support,
