ahmadramadan
- Jul 18, 2015
- 8
Hey all
Hope everyone is ok,I have couple of questions to ask
1. Where is the threshold in the code to distinguish between beam- column and column in design, or in other words what is the biggest axial force that we can ignore and consider the beam-column as a beam
2.Generally speaking if we ignore torsional in design the building will stay safe with some cracks(taking only compatibility torsion not equilibrium torsion ) is this right???
3. after Etabs distribute slab force in beams, how can I calculate the redistributed force on beam ???
Thank you all
Thank you all
