Hi All,
"Dow Corning 730 Solvent resistant adhesive/sealant release a small amount of acetic acid during cure. This may cause corrosion on some metallic parts or substrates, especially in direct contact or when the cure is carried out in a totally enclosed configuration which would not allow cure by-products to escape."
This is from the tech sheet.
I am wondering they will be applied on alodined aluminium. Just underneath 8-32 socket head screws which are CRES steel. The acetic acid that will be released is very minor but the socket head sits inside a counter bore making the bi-products escape a lot harder.
My question - will this tiny amount affect my chromated al?
