Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Do you really need the mortar above and below the tie for the small area that it's going to impact? My argument would be no, and therefore the coursing stays pretty well the same.It really doesn't work well in practice. You have a 3/8" tie, and a 3/8" bed joint. That doesn't work, so you have to increase your bed joint thickness to something closer to 3/4". Now your column coursing doesn't match your wall coursing. If I specify masonry columns that require ties, I specify open blocks for the purpose.
Is there any difference in strength? You have a little less web to deal with so less of the block takes compression, more goes to the mortar. Is this significant?It really doesn't work well in practice. You have a 3/8" tie, and a 3/8" bed joint. That doesn't work, so you have to increase your bed joint thickness to something closer to 3/4". Now your column coursing doesn't match your wall coursing. If I specify masonry columns that require ties, I specify open blocks for the purpose.
