ACC vacuum testing
AndreChE
Chemical
PT
Dear all
We have recently switched 3 complete cells of our ACC system.
The old ones were cut and new ones were welded.
The test that is being done (before plant startup) is a positive leak test.
We pressurize the system up to 500-700mbar (design pressure) and check pressure loss.
However, since it is a vacuum system we would like to test under vacuum conditions before plant startup.
Is there any procedure, API or recommended practice for that?
AndreChE
Double posting is not permitted on this forum.
