With gpavlab recommendation, make sure to generate an arc
subdivided with equal radial lines, then the letters can be equally spaced at the intersections of the arc and radial lines in order to get a uniform presentation. The degrees of rotation the letters can be determined from the angular positions of the radial lines. Invoke the LI command on the radial lines for their angular positions.
