HomeMadeSin
- Mar 17, 2003
- 77
I've got a potential design that requires a motor to have a "hollow" rotor design. I've seen rotors that have "spoked" lams that lead me to believe that the inner area is not necessary from an efficiency of the motor standpoint. I'd like to find an existing design that has can accomodate a 4" ID hole reamed through it. OD of the rotor is not critical. I only need about 3" oc stack height and 3/4HP @ 3450rpm, so it would be a low L (length), high D (diameter) ratio. Pipe dream?
